rod tubes??
marshman
Slidell, Louisiana
I want to make rod storage with tubes... am I correct In remembering that there are golf club tubes that work perfect?? or do I just need PVC pipe??
You are correct about the golf bag tubes and yes pvc will also work. Use what ever is more available to you. Good luck and keep us posted.
If you wind up going with PVC, remember to use the lightweight stuff. No sense adding extra weight if you don't have to. You can flare the ends with a heat gun and a wine bottle.
https://www.grant-trebbin.com/2013/06/flaring-end-of-pvc-pipe.html?m=1
Oh man golf tubes were a beauty idea, just ordered 4 off Amazon. Thanks for the tip on that! =D>
[url=https://www.tinboats.net/forum/viewtopic.php?p=364973#p364973 said:
richg99 » 31 Aug 2014, 09:30[/url]"]If you wind up going with PVC, remember to use the lightweight stuff. No sense adding extra weight if you don't have to. You can flare the ends with a heat gun and a wine bottle.
Thanks richg99 for the link!
