BaitCaster
So, took the boat out for the first outing since installing the fish finder. My transducer throws a pretty bog rooster tail at WOT. Is this normal/expected? Anything I should do about it?
wasilvers said:Smile and wave!
Get back at the jetskis!
Tell people my roostertail is bigger than yours!
Or you could just move it up higher so it's not so low under the boat. My humminbird actually has a rubber piece they made to put between the transducer and mount to reduce the effect. It works great, but makes me afaid if I hit anything, the transducer will be damaged instead of flipping up like it should.
[/quote]BaitCaster said:That's great. Thanks. I may have got that rubber piece with my transducer. What does it look like?
Quackrstackr said:It's most likely channelling water up through the hole in the mount. I capped mine with a piece of SS sheetmetal to fix the problem. Mine would actually spray back up over the transom and soak your back at speed.
BaitCaster said:Found the plug and installed it Friday.
fender66 said:BaitCaster said:Found the plug and installed it Friday.
Where'd you find the plug? Was it included in the box?
dyeguy1212 said:fender66 said:BaitCaster said:Found the plug and installed it Friday.
I've never seen that with any of the humminbirds I've owned. It does look like a loop of electrical tape would be about the same though.
:beer:fender66 said:Very funny you said that. I just came in from working the trailer after being out today and wrapped some electrical tape around it. Good minds must think alike. :mrgreen: =D>
