Tsuswimming
Hi all i'm fairly new to these forums and they are great for information, and am currently working on a mod of my own, will post it up soon, but my problem is:
I have a air compresser usually runs about 60-90 psi. Max it can run is 125 psi. Can rent a bigger one if thats the problem.
I bought a cheap sandblaster at harbor freight for like 10 dollars. Running speed is 75 psi and the max is 150 psi.
I also bought 24 grit walnut shells 25lb bag. At harbour freight for like 20 dollars.
So it is not removing the paint nor coming close not even making scratches in the paint, i was wondering if its my air compresser or sand blaster i need to upgrade on or are the walnut shells to fine or should i get sand also should i get a bigger air compresser?
Any and all help will be appreciated and also like i said i will be posting my mod soon.
