Now, for the transom wood question. It is completely rotten and flexes with the motor installed.
Also, I need to put a 2x2 under the motor clamp to get the motor to the correct height.
What would you suggest about replacing this wood?
Should I increase the height between the end caps to gain the additional height?
Is there a reason I should/should not increase the size of the interior wood (+2 or +4 inches) further down the transom?
Any other thoughts are welcome as well.
