Source for DIY T-Slot or T-Track rails, gunnel track system
DaleH
TinBoats Supporter
Eastern Mass
Found this on Amazon, $15 for 48" of aluminum T-Track you could mount on your gunnels to slide and/or position rod holders and other fishing accessories around. The design uses the head of a 1/4"-20 hex head bolt slid into the track as the fastener.
https://www.amazon.com/Orange-Aluminum-OA7150-48-T-track/dp/B00VS25W66/ref=sr_1_2?ie=UTF8&qid=1458920213&sr=8-2&keywords=t-track+aluminum
Not sure I'm going to add some, but a recent post got me to thinking if there was any DIY options out there, vs. the boat makers like Tracker, Lund and CrestLiner who have their own versions as OEM installs.
riverrat717 said:
https://www.8020.net is another one.
Which product? I didn't see any T-slot extrusions when looking around.
FYI, here's an eBay source for that track I pictured where the cost is just over $20 for the 48" track. Not too bad!
A year or so ago, I bought some of this extrusion
https://smile.amazon.com/80-20-Series-T-Slotted-Extrusion/dp/B001F0K4JG?ie=UTF8&keywords=80%2020%20extrusion&qid=1458922312&ref_=sr_1_11&sr=8-11
My plan was to use it on my kayak(s). Never got around to it. I did, recently, use a small piece to make an adjustable transducer holder for my new hull. Since I haven't had it out more than once, and it needs some adjustments, I haven't posted anything about it prior to this thread.
I had to slightly round the galvanized bolt heads to let them slide easily. I can see from the unit that Dale H posted, that that extrusion has a flat bottom and would probably work better. richg99
