putback
Can't find this in search. Can't find the amps on the starter and it's not wired so I can't check it under load. Do'es anyone know the original starter wire gauge or the amp draw on a '63 40hp Evinrude? While searching I also saw the term continuous run solenoid. I expected to use a common starter solenoid matched to the amp load. I'm just putting this basket case together so I want the right parts on the 1st try.
