Starting a used motor after sitting for years
djcamera
My '86 Mercury 75hp locked up in October. So I found a guy with the identical motor for sale, but with a bad lower unit. Guy says the motor has sat for at least five years. In central Florida.
I swapped the gearcase and hung the new motor last week. Tomorrow I'll finish the wiring and I'll be ready to turn the key. I literally have no idea what's going to happen.
I tested the motor when i got it. Compression test shows 130 on all 4 cylinders (cold, with a squirt of oil). Good spark x4. It turned over nicely for the compression test. We didn't try to start it because it wasn't hooked to gas or a hose or a throttle. I figure (maybe foolishly) that if the compression and spark test good, everything else is fixable.
So...how best to be ready when I crank it for the first time? Dream scenario is it goes "VROOM" and I'm in business.
maintenanceguy
TinBoats Sponsor
South Jersey
Even if it goes "vroom", I'd want to disassemble and clean the carbs before I trusted it on the water. I'd also change EVERYTHING from the fuel tank to the carbs - hoses, fuel pump, water separator, water filter, etc. Old hoses can degrade inside and tiny bits of rubber sucked into the carbs can ruin a day on the water and result in an expensive tow.
djcamera
Good tips. Thanks.
