Stop Pin - manual trim vs power trim
Callmecaptain
Just curious, the stop pin is only for manual trim units right? I swapped to a power trim and like to be able to trim all the way in at times so I removed the stop pin. Should be fine right? Thanks
I use a transom saver so I think I'm fine there, I just wasn't sure if it's better for the mid section of the outboard to rest on the stop pin instead of resting all the way onto the swing bracket, but it probably doesn't matter. Thanks anyways :fishing:
