Mike Redmond
- Joined
- Feb 21, 2009
- Messages
- 157
- Reaction score
- 0
This has been nagging me for a while.When you put a fishing boat on a trailer, you have to strap it down,I use nylon straps with the binders factory installed in them.The problem I have with those,is either they are to close to the hull and vibrate themselves crazy in the wind and rattle of the side on the boat thus damaging it,,I jury rigged them once and managed to have the binder halfway across the midle of the boat it solved the rattling on the side of the boat BUT it wobbled so bad in the middle that the straps cut them selves on the edge of the boat///solved this by putting some rubber pieces under the straps on the boat edge but that cranking devise still wobbles like crazy keeps me nervous,,where I go fishing you really have to tie your boat down,a friend of mine even installed the binding straps you see on semi trailers....any suggestions out there..Thanks Mike
