Tightening Tiller steering - 25hp Johnson
Frank29
Have a 25hp 1996 Johnson. J25RMEDC. Steering is a bit loose, so I tried tightening the bolt under the cowl but seems to have kind of bottomed out and still not tight enough. Is there a friction block or something I need to change?
The steering friction is not under the cowl.
https://www.marineengine.com/parts/johnson-evinrude-parts.php?year=1996&hp=25&model=J25RMEDC&manufacturer=Johnson&section=Midsec
The friction adjusting bolt is item 65
Sent from my SM-G903W using Tapatalk
I have a 1975 25hp evinrude doing the same thing. Tried adjusting the tension and didn’t make any difference. Looks like it would be a pain to take apart does anyone have any experience fixing this issue? Sorry I can’t help
thank you gypsy400. i see there is a bolt and a friction block, block must be worn. is that hard to change?
I've never had to on an omc motor.. and I have motors from 1971
