F fishbum Well-known member Joined Jul 22, 2012 Messages 89 Reaction score 0 Nov 15, 2013 #1 Anyone know if a 120 can be swapped into a tracker that has a 90 If not what would have to be done ? Thanks
S sjsykora Member Joined Dec 30, 2012 Messages 9 Reaction score 0 Nov 28, 2013 #2 The 120 will bolt on the 90 pump. The gear ratio on the 90 pump is 1.14:1 and the ratio on the 120 pump is 1:1. Engine cover may not fit unless Tracker used the same cover for both engines. Steve.
