itmustbeslim
I am having a ground issue, I think. I was wondering if any of you could help.
I finished the harness and converter on my car this morning (instead of studying for my employment law final) and using a circuit tester all of the poles lit up.
When I hooked it up to the trailer I am not getting any lights. I have diagnosed the problem to this point:
When using the circuit tester and connecting the checker to the ground spot on the car I am getting continuity from the trailer harness back but no lights. When I hook the checker to the ground wire on the trailer harness I am getting continuity back (ground not connected to trailer) and still no lights. Then when I hook the ground to the trailer and hook the tester to the trailer frame I am getting no continuity and still no lights, the trailer is painted all the way around. I don't think I have a tilt trailer (This is my first boat) so the problem must be elsewhere. The spot where he had the ground wire connected when I got it was to one of the U bolts on the tongue.
My tail lights are raised on metal posts but have no ground wires coming from the light itself which seems kind of weird. What would you guys do next? The wiring itself is pretty old so I may just spend the 15 bucks and put it new wiring, besides the guy jury rigged the connections using spliced connections instead of just butt connectors which is something I want to change.
So should I figure out putting a ground on each tail light even though there is no ground wire coming out? What else should I check or should I just replace the wiring?
Thanks for your help.
