Ultimate Bunk Boards
bassin026
High Falls, Georgia
I just purchased a set of these bunk boards ( I am a senior with back and hip problems) these are really great BUT
I'm having problems, as the ramps are at an angle when I position the trailer just over the water the winch strap is as tight as it can get. How do I relieve this tension without getting hurt????/
I think Popeye gave you pretty good advice on the other thread where you asked. Leave some carpeting at the front of the bunk.
You can also back the boat almost all the way into the water so that the stern starts to float - then crank up a little and loosen the strap - boat should slide right off
Popeye's idea worked great, I had some indoor/outdoor carpet that I used on the decking.
I put a piece on each and that's why we have this forum, too help the other guy out;
Thanks Popeye
