handyandy
llbaker2 said:handyandy said:just leave the plug out water will should come in while on plane from the hole catching some of the water as it goes by. Then when at rest water will kind of come in and out of ti as the bot rocks and moves. Leave the plug out and see what it does without the plug in, just leave the lid open watch the water level while on plane with the plug out.
This video explains the idea more, and he takes his passive livewell a step further with more holes a slight angles.
https://www.youtube.com/watch?v=Rl2ucnabA9k
The video is basically the same setup/idea as my livewells except I just have one 3/4 inch hole in center of well. Still seems to me that since the boat is riding higher when planing that the level would drop at least partially and then refill when not planing. Guess they used a two inch standpipe to prevent all the water from draining out when on plane. Guess if I put minnows in well I will need to put some sort of screen over pipe end or use a perforated bucket or I will lose some of them out the pipe opening. Like you said I guess I need to leave hatch open and watch water level when planing and when off plane to see if it is doing what I think. Should be easy enough to do. Have one tank under helm and one under passenger seat. Can just leave passenger seat lid open when underway so can watch it. Guess I got confused because I've read about how most livewells have pumps and aerators when mine doesn't. Guess I will just go with it and see how how well it works. See how long fish stay alive.
I'd do the easiest thing first which is just try it and see what it does not like you have anything to lose doing that.
