longshot
After less than 1000 miles and about 10 launches I noticed some grease on one of my wheels and figured the seal must have failed. So I pulled it down to repack and the inner bearing was locked up. And the part of the spindle where the seal rides had weld splatter on it that had to be cleaned off. When I pulled the other side off it was full of water and on the verge of failure. It also had weld splatter on it. Needless to say I'm not impressed with it. You would think a bearing would last more than 1000 mi
