This always confuses me. I just used the calculator, and everything I put in said if I dropped down in pitch, I would gain RPM but lose speed. Going up in pitch would gain speed but lose RPM. Right now im running around 5125 RPM's, with max being 5500. Im also looking to get more speed, but also dont want to go too low in the RPM range.[url=https://www.tinboats.net/forum/viewtopic.php?p=317268#p317268 said:turbotodd » Yesterday, 22:26[/url]"]What is the max RPM for your particular motor?
If it was 5000 max, a 14" prop would get you real close. If 5500, drop to a 13". If 6000, somewhere between a 12" and a 13" (probably a 13"). Just guessing here, but at least with your RPM data, it should be somewhat educated. I don't know how much top end speed you're going to gain, maybe a couple MPH, but if your max RPM is supposed to be 6000 and you're at 4600 now, you're really lugging the engine. If you dropped down to a 13" prop to get the RPM up, it'd probably pick up a mph or two AND come out of the hole better AND use less fuel at cruising speed. A win-win-win.
https://www.rbbi.com/folders/prop/propcalc.htm
That's a good calculator program that will usually get you real close. I put mine in there and it was spot-on to the tenth of a MPH (2.08 gear, 6080 RPM, 11" pitch and 6% slip). The GPS data showed a constant 28.6 mph with an occasional gust of wind pushing me to a 29.0-29.1. I had good air that day.
