MrGiggles said:The only time I could see it is if you were networking a bunch of stuff, like multiple graphs and a trolling motor all tied together. A pro would know all of the necessary cables and hubs to make it all work together.
Otherwise it's not rocket science. Just power/ground and run the transducer cable.
the hammer said:I just remembered I called Garmin and the rep said it’s possible the current transducer might be compatible with the new one. If not, the bracket could be compatible. If that’s not compatible, it would still be similar enough it wouldn’t require a lot of “caulk” (I can’t remember the term he used)
LDUBS said:the hammer said:I just remembered I called Garmin and the rep said it’s possible the current transducer might be compatible with the new one. If not, the bracket could be compatible. If that’s not compatible, it would still be similar enough it wouldn’t require a lot of “caulk” (I can’t remember the term he used)
That is some good news!
