danlva said:
Currently cleaning out the inside of the boat. Have to get rid of all that rot!!! Starting to plan out the paint. I'm throwing around the idea of covering the inside with herculiner (or similar product). Anyone have good/bad experiences doing this?
I "tried" to do Herculiner on my build. The product sucks! Don't bother. It's the consistancy of kitty litter in rustoleum that's almost too dry to spread. It's too think for spray on applications. The "rubber clumps" are too large to grab a roller. Yer stuck dabbing with a brush, multiple coats. There's no catalyst or hardener. Expect 5 day+ curing time. I had used 2 quarts $80+tax, and a whole bunch of materials on mine. I got as far as a 2-3" "strip" of build across all my seams, and enough to cover my transom pads. Calculating square footage per the label, I should have been able to do this in one quart can. I had barely enough to do it in 2 quarts. Gallons were a little over $100 at the time. This product requires multiple layering, and you have to add the layers in a certain time frame after the last layer. Layers must adhear to tacky lower layer. If you choose to use it, you better have an entire weekend to devote to the painting process. I'm thinking that a gallon would have been enough to cover just my seams and ribs...and entire floor or deck would be out of the question in one gallon. And, the consistancy would be garbage.
I have watched a buddy use Duraliner on a Jeep. Duraliner requires a hardener. As soon as it's mixed, you have to put it down. This one will roll. It costs more. It has better coverage.
Try yer google-fu at finding a Line-x Franchise around yer neck of the woods. They will mask and spray a truck bed, black for $250....which is a heck of a deal after you look into the prep time, masking, and labor to come out with a desirable finish. They generally charge an extra $175 for tinting...in any color you want.
Duraliner and Herculiner don't hold paint very well...I hope you like black.
My
strong reccomendation is pay the professional. It will come out the way you want it, the color you want it, it can be "used/fished" quicker, and it comes with a warranty.
Oh, and my vote is for the shark graffics.
