14' Mon Ark what year?
Philcast
Ok folks, after searching everywhere i could think of. I cannot find any information on my boat.
The plaque just under the top lip on the right side of the bow says
Mon Ark Boat Co
Model 1464
Serial 7670
The registration says its a 1963 The boat measure 1436. Pictures to come later, its dark right now.
Anybody out there have any info?
Here is a link to an archive of Years of Model Numbers for Monark boats.
Click on each year - a couple times each as the more you click the bigger the font gets and it starts out very small.
That model number shows up from 1959 to 1962. There are no records for 63 & 64. And then continues in 65 on.
So it is a good chance the 1963 is correct.
However the list says a 1464 measures 14 feet with a beam of 56".
Did you check to see if there is a plate on the inside of the transom? That is where my Monark plate is mounted.
Good luck.
https://www.fiberglassics.com/library/MonArk
Thanks Clint, I have seen that site. There was remnants of something nailed to the transom with four tacks in the top right corner, but its long gone. I was just curious to see if snybody had anything on the serial number indicating an age. I may call SeaArk and pick their brain a little.
