15 HP Johnson water pump question
Passport
I have a 1989, I think, 15 HP Johnson that is not spitting water so Im assuming the imperller is bad. Is this a DIY repair? I have googled it and it seems pretty straight forward but want to know if I need to check any other areas. Also can you tell me how to check the water tube to see if it may be cloged, can I simply shoot some water up there from the hose?
Thanks in advance.
PP
It's a pretty easy task for you to complete. There could be a number of reasons why the water isn't spitting water.
Here is a good read: https://www.leeroysramblings.com/water_circulation.htm
I don't know where or how you are testing the motor, but if it's in a bin/can, make sure that you have the motor deep enough so that the watever comes over the top of where the water pump is... not just up to the water intake.
Hope that helps.
