• If you have bought, sold or gained information from our Classifieds, please donate toTinBoats.net and give back.
    You can become a Supporting Member or just click here to donate.
Part For Sale 1966 Johnson Short Shaft 6HP outboard motor
jbird68
Morrison, IL
Morrison, IL
I have a 1966 Johnson Short Shaft 6HP. Motor runs great. I put a new water impeller in it last year and new lower unit gear lube. The shift handle was broken off when I purchaced it. I attached a piece of aluminum channel to what was left of the **** handle. Otherwise you need to remove the powerhead to change out the whole shift arm. And thats if you can even find a replacement. I works pretty good but it is a little longer than it needs to be.
1966 6HP Running in a Barrel
Asking $275
Pick up In Morrison, IL
  • 1966 Johnson 6HP Outboard Motor.mp4
    34.6 MB
