juggernoob
A few weeks ago I picked up what was advertised as a 1980 Johnson 9.9hp with a broken pull starter on Craigslist for $150, owner said it ran fine last year. I have a 78 Johnson 9.9hp that I figured could used some parts if it didn't work. Well it turns out to be a 1977 Johnson 15hp 15RL77M with what looks to have once had an electric starter? So far I've ordered all the parts for the pull start and that seems to be working, and replaced the broken air box. The positive cable from the kill switch, in the 2nd/3rd picture, was just hanging and the kill switch does not seem to work, I'm guessing this goes into the Power Pack? I foolishly tried pushing the cable in and started the motor then couldn't get the kill switch to kill the motor. Which brings me to what might be another issue. When the motor started it seemed to be stuck on Fast with the prop gear engaged. Turning the handle from Start to Shift of Slow doesn't seem to change the RPM of the motor. Linkage stuck? I'm going to pull of the lower unit to do the water pump. The other thing to note is that the motor wouldn't start until I sprayed Johnson Starting Fluid in the Air box. I want to fix the kill switch before I try starting it up again.
