South Sound
I am debating whether or not to remove the floor. I have seen some videos that say the floors in smokercrafts have foam sprayed through holes and are basically glued to the hull. Also smokercraft has a lifetime replacement on their floors. Does anyone know for sure what is under the newer Smokercraft floors. If they are in fact spray foamed on and have lifetime warranty, then I might leave it and build a "screwed down and riveted frame over it so I can remove the frame from the floor if I need to have it replaced. I would just start unscrewing the floor, but it has split seats that are on top of the floor and riveted into the boat. I would have to drill them out, then take out the floor to find out what is under it.
Thanks,
Josh
Thanks,
Josh
