[url=https://www.tinboats.net/forum/viewtopic.php?p=364412#p364412 said:rktman » Yesterday, 12:26[/url]"]Has anyone replaced their 25 hp powerhead with a 35 hp unit on a 2000 Johnson motor (jet).
I'm think of doing the swap if everything fits well.
I have the larger carbs already on it.
Thanks
[url=https://www.tinboats.net/forum/viewtopic.php?p=364498#p364498 said:Pappy » Today, 09:19[/url]"]Not in model year 2000. Engines were rated at the propeller or in your case the jet unit.
You would have 18 on the cowling if it were the 25/18 jet.
In your model year the 35hp (outboard)was a 3-cylinder.
Yours is the32 cu. in. 2-cylinder cross-flow.
For your engine you already had the correct 30hp cylinder and crankcase and the large intake manifold. Same as the 30hp.
[url=https://www.tinboats.net/forum/viewtopic.php?p=364497#p364497 said:airbornemike » Today, 09:18[/url]"]I've got an 2002 30hp johnson jet, I want to have mine built after the fishing season winds down. How did changing the carbs help?
I plan on having someone do the work for me, porting, carb reeds......if I could get 10 mph more I would be happy. Let us know how it works out for you.
Thanks
not sure what hp's were available in 2000 but the 20,25,30 and 35hp motors all have the same powerhead and the different carbs and or manifold intakes dictate how much HP the powerhead produces for those modelsrktman said:Has anyone replaced their 25 hp powerhead with a 35 hp unit on a 2000 Johnson motor (jet).
Thanks
shawnfish said:not sure what hp's were available in 2000 but the 20,25,30 and 35hp motors all have the same powerhead and the different carbs and or manifold intakes dictate how much HP the powerhead produces for those modelsrktman said:Has anyone replaced their 25 hp powerhead with a 35 hp unit on a 2000 Johnson motor (jet).
Thanks
