lundwc16
Haven't posted in a while as I just started using my 14' Mirror craft again. I have a 1977,25HP, electric start Johnson, tiller motor, mod # 25E77S. Under load the engine has started popping out of gear, & sometimes I get a "bang" like it hits an underwater object. I have taken the vertical access plate off the lower unit & checked the linkage connection, looks fine. I have drained the gear case grease, & it looks clean as it should. Anything else to check, or do I need to dig into the gear case?
John
John
