I have a 48SPL with a bad forward gear does anybody know if the gears on all 48 SPL will interchange or was some years different?
Thank YouAm about 90% sure they are all compatible but when I need an answer like this the first place I go is into marine engine and start looking at the fwd. gear/pinion gear on different year models and see if the P/Ns are the same.
About the only thing that will take out a fwd gear is incorrect shift rod height, incorrect shift linkage adjustment or slow shifting. Make sure all are correct when going through the gearcase and adjusting
