9.9 Max- can i go more HP?
aeviaanah
Stanislaus County, CA
I bought a 12' aluminum fishing boat, Valco brand. I am currently rebuilding it...
The tag is missing that would show the max HP. I looked at similar boats and they say 9.9 is max. What determines the max HP? Obviously the manufacturer but is there anything I can do to put a 15 or 20 HP motor on there? I already got the transom ripped out, I am a steel worker and can work aluminum.....If i decide to go with a bigger motor, what should I do? Bigger gussets? Thicker transom boards? Thanks!
Yes, yes, and yes. Beef up the transom and go for it! A lot of 9.9's are really just 15hp motors with smaller carbs.
As long as you dont put a motor thats much heavier than a 9.9 2 stroke (cause thats what it was rated for) you should be fine. Especially if you beef up the transom a little. Maybe a little thicker wood and put 2 knee braces instead of 1? If you go all Aluminum that would be even better. I wouldn't go much more than a 15hp. 20hp at the most! You will be flyin.
sweet that is good to hear...all aluminum on the transom eh? like formed aluminum panels or solid stock?
two gussets sound good. will a jack plate affect this rating at all? i plan on fabricating up one of those as well
Here is the formula taken form the US Coast Guard Backyard Boat Builders Regulations (Just do a google search)...
Kinda technical...but if you exceed Max. HP Limit, your insurance will not pay for any claims if that boat was in an accident and someone got hurt.. not to mention you would not have a leg to stand on in civil court,,,,
Sec. 183.53—Horsepower capacity
The maximum horsepower capacity marked on a boat must not exceed the horsepower capacity
determined by the computation method discussed in paragraph (a) of this section, or for certain
qualifying boats, the performance test method discussed in paragraph (b) of this section.
(a) The maximum horsepower capacity must be computed as follows:
USCG 2003 BOATBUILDER’S HANDBOOK | PART 1
58
(1) Compute a factor by multiplying the boat length in feet by the maximum transom
width in feet excluding handles and other similar fittings, attachments, and extensions. If
the boat does not have a full transom, the transom width is the broadest beam in the
aftermost quarter length of the boat.
(2) Locate horsepower capacity corresponding to the factor in Table 183.53.
(3) For a boat with a factor over 52.5, if the horsepower capacity calculated in Table
183.53 is not an exact multiple of 5, it may be raised to the next exact multiple of 5.
(4) For flat bottom hard chine boats with a factor of 52 or less, the horsepower
capacity must be reduced by one horsepower capacity increment in Table 183.53.
Table 183.53—Outboard Boat Horsepower Capacity
[Compute: Factor = Boat Length X Transom Width]
If factor (nearest integer) is 0-35 36-39 40-42 43-45 46-52
Horsepower Capacity is 3 5 7.5 10 15
[Note: For flat bottom hard chine boats, with factor of 52 or less, reduce one capacity limit (e.g. 5 to 3)]
No remote steering, or less than 20[sec] transom
If factor is over 52.5 and height
the boat has
Remote steering and at
least 20[sec] transom For flat bottom hard chine
boats
For other boats
Horsepower capacity is
(raise to nearest multiple
of 5).
(2 X Factor)-90 (0.5 X Factor)-15 (0.8 X Factor)-2
Outdoorsman
Outside the liability issue, running a 2 stroke 15HP should not require any transom mods. The 2 stroke 15hp, develop the extra hp at higher rpms. The max torque applied to the transom will be getting on plane, where the 15 will have the same torque as a 10.
Now, going larger hp, or a heavier 4 stroke, beefing the transom is advisable.
see, i wonder about that. i have 3 hulls that are clasified as , comercial ' they don't have a bia plak' just a red warning tag telling you they don't meet cg specs . the boats really don't have a hp power rating,i mean you can't put a 75 on a 14 footer but i know a lot of people running 40 hp 3cyl mercs on em . but i would check with the insurance co just to be sure .
58
the boat has
boats
For other boats
of 5).
Outdoorsman
Hey thanks for the reply!
Thanks, I am interested in a 4hp motor. What transom mods do you recommend? Beefing up gussets and stuff?
No insurance on this guy, its just an old fixerup boat. Possibly the motor when i buy it will tho. Thanks.
My 13 1/2 foot Gregor has a maximum hp rating of 20. I sold the 20hp Johnson that it came with and bought a brand new 15hp four stroke Honda. I didn't weigh it but it was heavier to mount than the old 2 stroke. I think a 9.9 would have been adequate in my case but oh well.
Just let that 4hp screem! ;) OK I'm betting you ment 40. I have no experience in over powering by that much. Just make sure you attach that lanyard during the testing phase.
What I'd do is research what 9.9's are actually 15's with a smaller carb, then put the bigger carb on. Possibly even bring it in to the shop to see if it can get bored over and get a bigger piston in it. This way the cowl still says 9.9, and you can run it on restricted lakes :wink:
The valco's I use to see were pretty stout boats, I am sure a 15hp 2 stroke would work fine. My 14' richline w/9.9 puts it on plain at 12 mph with me alone. I think if you went to a 15 it would push your 12' great.
my boat weighs right around 130 LBs dry with nothing in it, 12 ft flat bottom. with 10HP 2stroke weighin in about 75 LBs she cruises at 21MPH with just me. Absolutely not too manuverable at those speeds but gets from A to B in a hurrray! Debending on your hull, a semi v would probably do well on plane with a 10 but 15-20 would probaby get ya similar speeds. Lil boats sure are fun!
they do not have a BIA plate "just a red warning label telling you that they do not meet specifications cg. boats do not really have a power resume, I mean you can not put a 75 on a 14 footer, but I know a lot of people running 40 hp 3cyl mercenaries on em. but I will check with the cooperation of insurance to be sure.
You bet thanks for stoppin by!
Sweet good to hear...ill just have to stouten up the transom
Lol ill just paint a 9.9 logo on there lol...
Yea i meant 4stroke...not too interested in a 2stroke motor.
How fast that 15hp goin?
Oh it'll go fast enough for me. I'm still in the break in period and have only ran it a few times in the water but it's plenty fast enough to get the job done. I have it trimmed up to the highest setting to help keep the boat level and that's with a passenger in the front.
My 14' Valco has a 7.5.
It seems to be adequate, but someday I'd like to get something bigger.
Check this out:
https://youtu.be/koNjVSNk4v0
Sweet, good to hear, can you take a guess on mph? Still deciding on HP.
Check this out:
Sweet, i never thought of takin this baby to the ocean...just always though of freshwater. Sounds like fun. That is a 25 HP tho eh? Looks like she gets it on.
I've got a 15hp 4 stroke Merc on my 14' Grumman V and it planes out in a heartbeat when I'm solo. I can about keep up with an older jet ski! No speedo but I wouldn't want to go any faster on it, honestly.
