Bassproshops Marine Panel
evattman
Middle TN
Ok.....I am really a novice at this and I lost the "how to wire" diagram. If anyone has one or has the knowledge to explain to me how to wire this up it would be GREATLY appreciated. All Im wiring is bow and stern light, deck lights and bilge pump for now.
Thanks
Just a switch panel isn't it? Line (battery power) to 1-side of the switch (it may even be marked), and load (power-consuming item) to the other side. If it has illuminated lights to show when power is on, it will make a difference which side of the switch you connect the Line to.
ST
Switch and fuse(breaker)go to positive side of battery,then to load.
Are you wiring up your bow and stern lights on different switches?
Does your bilge pump have a float?
that switch panel has one power wire if i remember right from the battery and then you put female wire connectors on the outputs of the switches and a single ground to make the switches light up i think that is all that comes off of that switch panel is one red power wire and a black ground hope that helps
