Battery Question
hdavis821
I am putting two batteries in my 14' flat bottom and and I was wondering about the way weight of them being upfront or should I move them to the middle of the boat? Anyone have suggestions?
I have a Lowe 1436 and I cut the top off the middle bench and cleaned out the Styrofoam and covered that with plywood and hinged it. I put two batteries in the bench, one on each side and wedged wood so they don't slide. And I secured a two bank charger to the wood and it looks real clean.
Sent from my SM-N910H using Tapatalk
Take the boat and batteries to the lake before you mount them, along with your normal load of gear for a typical day for you. See how the boat sits/runs/fishes with the batteries in different positions. It may take more than one trip to sort out the best solution for you and your boat.
