Control box electrical question Mercury
buckeyeBEN
Pickerington Ohio
Long story but...
When new control cable installed, I can't lift the idle/throttle lever and get the ignition to turn over.
Is there a way to bypass this " safety" feature?
You probably need to open up the control box to see if something is jambed up. You should need to push in the button to move the throttle/shift lever. There should be a neutral safety switch inside that won't allow it to crank over the engine if it detects it's already in gear. I've had mine apart several times and you have to get things lined up correctly when putting it back together so something may have moved around.
