bassnbrian
- Joined
- Jun 16, 2009
- Messages
- 44
- Reaction score
- 0
lol whatever man, we have all seen FLAT bottomed "jon" style boats with a V shaped bow...and when we do...they are sold under the "mod V" label.
LonLB said:bassnbrian said:I disagree that the definition is that cut and dry...just look around, there are TONS of flat bottom boats with V style bows that are called MOD-v.
Their definition might be wrong , but nevertheless it is the label they are being sold under
https://www.trackerboats.com/boat/?boat=3425
That boat has V.
This pulled from the description
"The Mod V design means you’re in for a much smoother and drier ride than standard flat-bottom boats."
This link has the specs, and lists the deadrise-again a measure of the V.
https://www.trackerboats.com/boat/specs.cfm?boat=3425
bassnbrian said:lol whatever man, we have all seen FLAT bottomed "jon" style boats with a V shaped bow...and when we do...they are sold under the "mod V" label.
bassboy1 said:bassnbrian said:lol whatever man, we have all seen FLAT bottomed "jon" style boats with a V shaped bow...and when we do...they are sold under the "mod V" label.
So far, every boat you've linked to has some deadrise. Once you get past 0 degrees of transom deadrise (ie - dead nuts flat, not 'mostly flat'), you are into the category of mod vees. Believe it or not, it is cut and dry.
The flat bottoms with a bit of a triangle in the nose are pretty well a thing of the '80s - I've owned one before, and worked on a few others, but I don't think I could produce a link to one made today if I had to.
