DIY anchor winch?
thatkidhugo
Toronto, Canada
So I was at bps earlier on today picking some things up when I noticed they have these really nice electric anchor winches.. for a steep $150. I also saw a manual one for $90, if I were to pay $90 I'd rather pay the extra $60 for a electric one.
Anyways, I've looked around online and haven't found much information on making your own anchor winch.. also did a quick search on here but didn't find anything.
Has anyone pulled this off successfully?
8)
I have run a boat that had a pair of DeckHand electric anchors (DH-18 if memory serves me right). They are SLICK. Touch of a button and the anchor drops. Hit the button again and they raise automatically; and the motor stops when the anchor is retracted fully rather than the motor continuing to pull on the rope. They retracted quickly...lot quicker than I thought they would, and the anchors dropped in a free fall.
Now I think they can be had in a wireless version. Cool.
I thought the price was steep too, but I guarantee that if I had the space on my decks, I'd have at least one of them.
I love to tinker & make stuff, but these electric anchor thingies are something I'd just buy rather than trying to make. I figure by the time I had one that actually worked decent, I'd probably have at least $150 in it...with the way I do things, probably double that. And it'd probably sink the boat if it retracted and the anchor hung up on a tree limb or rock.
I've got a minn kota deckhand(I believe that's what it is)
It has a remote(wired) that's on the dash and the switch on the motor. The thing is awesome.
The only issue I don't like is that when you're anchored in waves, you can hear a bump on the bigger waves where the spool moves just a little. I remedied it by dropping anchor and then tied off to a cleat.
I picked it up used for 75 bucks. I've seen a few on ebay that are going for about 100
I had a manual one, but it rusted out after about 3 years
Sometimes the bell anchors stick in the mud and u got to break them loose manually if u don't the circuit breaker will pop
I've actually thought about this....I think a manual one may be doable. Electric...well there is more to that than you may think.
I have several old winches from trailers that I have replaced. I kept them for whatever reason. Now I am wondering if I can make one of them into an Anchor winch. It would be plenty heavy enough. Just spool the rope up. It may not lift to fast though. LOL... But if I could use the spool and get creative I probably could fix that...hmm now you got me thinking....just what I need another project....lol
Only problem I see with doing it this way is that the handle will be whipping around pretty good when you drop anchor. My anchormate has a free spool button that releases the drum from the handle for the anchor to drop. Otherwise the cranking on the anchormate is 1:1 and I would guess the crank on the winch is at least 5:1 so yeah real slow.
I made one for Our 2072 that's used for steelhead fishing in rivers with a lot of current, but we're talking a heavy anchor, as in 80# +. I'm in the process of making a smaller weight version for my tracker 1648 I'm doing now. When it's done ther'll be pics on here
The trailer winch would work. If you're in a saltwater environment, be prepared to replace it frequently.
The only problem I see is rode capacity. If you're using rope as your rode, doubt you'll be able to get much on there. Maybe use it as a capstan with rope. Steel cable will give you a greater capacity, but again, the elements won't be your friend.
just out of curiosity,how heavy of an anchor are you guys using?i use a 10# bow and 5# stern.i have a scotty hand retrieve on the bow and it works great.my boat is a 14.5 ' g3 and weighs close to 800 lbs. loaded.mind you i only have 50' of anchor rope on mine.
Nice anchor winch...but I'm more interested in that cover you have on the boat. Looks like a really cool tent. More pics please.
The trailer winch would have to be modified somewhat I know... I don't need a huge amount of rope. I usually don't anchor in stuff over 20 ft. So 50 ft of line is prenty.
