tcampbell011
I have some general questions, I have found people mentioning these Qs other places but no real definitive answers.
Should alum angle be capped where it could rub against the hull? How it this done?
I understand the difference in strength between 6061 and 6063 aluminum. Do you think having the stronger 6061 is worth having to figure out a way to make them fit nicely into each other? Is it worth having to make a shim each time you connect two angle bars?
