Thanks for all the replys fellas, sorry I've been working alot of O.T. lately. I havent had time to try the T.M. And lights together again on the same battery. Here's the setup- altogether I installed 3 LED lights and 2 courtesy lights and a 12v plug, I ran 2 LED lights to a toggle switch, 2 courtesy lights to a toggle switch, one rear storage LED light to a toggle switch, and one 12 volt plug-in for my spotlight to a toggle switch. All black wires from all of the lights and 12v plug in were spliced together and went straight to the battery, the red wires from each light(or 2) went to a toggle which had 2 prongs on each toggle (red wire in on one prong from light, red wire out from other prong to battery) all red wires from toggle switches were spliced together and then ran to a 15 amp fuse then to the battery. 30 lb. thrust T.M. hooked to same battery ( the T.M. is CLAMPED onto the pegs, the light wires are hooked to the WING NUTS on the same battery. Both ran at the same time that day, blew the fuse for some odd reason. Hope that did'nt confuse anyone, hope someone can figure this out for me #-o Thanks again! D.
