ShadowWalker
I got this with my boat and we got it started (after my dad informed me I had the fuel line backwards), but he had to use ether to get it to start. Once it started it would run. There is a knob between the choke and stop button that we don't know what it is for. It is connected to something in the carb through a linkage type thing. Would this be a fuel adjustment?
Also, there is oil leaking out of a hole in the lower part, but it is not nearly as thick as the lube you would use in the lower unit. Does anyone know what this could be?
The streak is the oil, it is coming out of the hole that is pictured.
Thanks
Another question I have is what ratio for the fuel does this motor use?
Thanks
