Increase top speed?
Colemanandrew
LOCATION
Aynor sc
I got a 97 yamaha 30 2 stroke on a 14 ft aluminum war eagle I can top off at about 35-36 but I know I can increase that a little bit. I know the motor can only handle so much any prop pitch increases and maybe how to lift the bow up some? I was thinking higher pitch prop and a whale tail or hydrofoil.
airshot
TinBoats Supporter
Perrysburg Ohio
LOCATION
Perrysburg Ohio
The whale tails rarely increase speed, give some lift and faster on plane yes, on lighter boats, but increase in speed is something I have never saw in my 60 yrs of boating. As mentioned, wot motor rpm is needed for calculations to be made. Keep in mind, that a higher top speed usually means a longer time to getup on plane, especially when any weight is added. Once you reach max wot rpm on that motor....that is it, only a bigger motor will increase your speed.
flatheadsteve
TinBoats Supporter
Berkeley springs WV
LOCATION
Berkeley springs wv
35mph is impressive from a 30hp on a boat like that. Others have already mentioned it but a rpm reading at wot would let you know if a prop change could do anything for you. Shedding weight wherever possible could gain a few mph but could affect handling if it messes up your weight distribution.
jethro
TinBoats Supporter
Henniker, NH
Yeah, when I take off my hydrofoil from my 25hp the top speed of the boat goes up by about 4 mph. Of course it takes much longer to plane. More drag with the foil that's for sure.
Crazyboat
NJ
A jack plate getting the engine up out of the water is the way to go, drop some weight if possible too. Knowing your RPM and adding a racing prop will add a bit too, but then you'll lose in other areas as a racing prop is built for that one purpose.
thill
Virginia, USA
I would be really happy with 36 mph with a 30 HP engine, but you might also want to try waxing the bottom of the boat. You will probably pick up another couple MPH.
Weldorthemagnificent
Either shave your head and don't wear a shirt or go downstream .😂 Sounds like you're hauling the mail already! Raising the motor on the transom sometimes yields a mph or 2. I used flatbar shims to dial the height in before drilling and bolting the clamp. I started with an inch but had to bring it down to a half to eliminate cavitation in the turns. I left the 2 shims in to share the load with the bolts. Rpm, like everyone says, will tell you where you're at. PXL_20231124_235730478.jpg
