MikeA57
I'm in the middle of installing my TM mount (https://s240.photobucket.com/user/MikeA57/library/TM Mount?sort=3&page=1) and I had the mounting plate drilled to install the power plug for the TM and also for a 12v outlet. I'm wondering though about cabling for the outlet. I plan on running a separate wire from the battery (in the rear) to the front of the boat. I figure I'll mostly be using it to plug in a cellphone charger but there will be occasions where I might plug in a 12v spotlight. I don't really know what the power draw will be at this point. I've got some 14/2 wire that I had planned on using but I'm not sure it would be heavy enough to power a spotlight for an extended time. I looked to see what the draw is on the 1,000,000 CP light I've got but couldn't find anything. I'm pretty sure it's discontinued now.
Thanks,
Mike
Thanks,
Mike
