dhoganjr » 04 Jul 2014, 16:55[/url]"]Gas issues are the #1 problem around here, most boats have a vented tank, the gas expands and contracts with the heat and cold. The ethynol in the gas helps absorb moisture, the water heavier than gas goes to the bottom of the tank, you go to start the engine and straight shot of water right into the engine.
Even so called ethynol free gas contains some ethynol and most of the new 2-strokes require 87 octane. Most of the ethynol free is 91 octane which burns cooler introducing more carbon build-up inside the engine, which equals more problems.
I draw the line at 2 months, at that time I drain the tank(s) if I haven't used it, and put it in the car. Top the car's tank off with fresh gas and add fuel injection cleaner. I then usually get worse fuel milage for a trip or 2, then all is back to normal. Next time I take the boat out, add new fuel and no problems.
It is a hassle but these new outboards cost too much to take the risk and what little time I get on the water now I don't want to spend trying to keep it running.
