Well, it's been 2 years since my father and I converted my Alumacraft 1470 to a mini bass boat. My buddy and I have joined a local bass league so we used a 100qt cooler as a livewell last year. I got sick of it so I decided it was time to make an in-deck livewell.
I didn't plan on adding a well when I first build the deck, so I needed to figure out where I was going to put it. I had a large storage compartment that had potential, so I took some measurements and started my search for a molded livewell tub. Couldn't find anything close to my dimensions on line and didn't want to spend the $$$ to get one custom molded. I was at the point where I was just going to buy some aluminum plate and fab up a well. I then went to the local boat parts store and there it was.. sitting in the aisle... a molded livewell tub that was as close as you could get to the dimensions I needed! I picked it up for $50 and started disassembling the boat for the build that night.
I have an 800gph Rule Tournament pump coupled to a V4 Flow-Rite valve. Since my plumbing and pump/valve will be below the waterline, I am able to locate the pump very close to the well (mid boat) and run one hose under the floor to the back where it would connect to a Forespar seacock.
Now that I'm using my storage space for the livewell, I decided I'd build a modular storage compartment to hold all the items that were in that space.
The storage compartment is constructed of 2"x2"x1/8" aluminum angle. I bolted the frame together for mock up and I will then tig well it together, removing the bolts when done. She'll be topped off with carpeted, sealed, 3/4" plywood.
