I Have "Lost" Two Combination Low Oil/High Temp Warning Modules On This Motor. The First $98 Module Was About 2-3 Years Ago, The Current One At The End Of Last Fall.
This Motor Mixes The Oil And Gasoline, With The Oil Tank "Hidden" Under The Cowl/Cover, And Straight Gas Into The Main Tank. Both Times Now, The Oil Got Down To The Warning Level ( Approx 1/4 Tank Of Oil Still In Sight ), BUT, The Beeper Comes On Steady, Which The Manual States Is High Temp Warning; A Beep On/Off Is The Low Oil Warning. Disconnecting The Brown w/ Black Tracer Wire Is The Book's Test To Confirm A Dead-Defective Module.
Question #1 - Can/Should I Bypass The Mixing Pump And Make This A True "Blue-Blooded" Premix Motor?
Question #2 - If I Do Bypass, What Type Of Temp Gauge & Sending Unit Would You Suggest To Take The Place Of The Beeper And Module?
