Hey everyone, I have read some articles and posts about converting a merc 9.9 to a 15hp just by changing the carb. However, I have done a ton of searching and cannot find whether or not you can convert an older 9.8hp the same way? It seems from what I have found, this conversion only works for the mid 90's and newer 9.9 because they use the same powerhead as the 15hp.
I have a 1972 Merc 110 9.8hp and would like to upgrade the carb if possible. Does anyone know if it can be done for my motor and if so what part numbers I will need?
Thanks,
Thanks,
