joncruiser
- Joined
- Feb 9, 2015
- Messages
- Reaction score
- 0
Good evening! Just joined and loving the site. Im starting my mod on my Lowe 1440 and trying to get a plan together before I start the actually build. Ive gathered a lot of components together over the course of the past few months but i like to have a plan before i jump right into it. once the project begins ill post a new topic in the Modification/build thread. anyways background, I'm running a 9.9 honda outboard and basically making this boat into an all around fishing/cruising/escape from work boat therefore i wanted some comforts. this topic is my basic idea for my wiring set up the diagram i drew up is not exact as far as placements but wanted to see if the configuration would be acceptable. i want to have 2 deep cycles or one deep cycle and one deep cycle/starter on a selector switch, i have a 6 gang rocker panel fused and jumped, the switches will control bow/stern lights/manual bilge/depth finder/ stereo on off/ possible deck lighting etc....low amp comforts....biggest concern is if my setup will work with the selector switch, battery choice, common "ground" and the ability to charge and keep charge using the motor.....any help with breaker placements and other safety precautions would be appreciated as well
