Ive finally started my jet build
https://www.tinboats.net/forum/viewtopic.php?f=21&t=34716
I mounted my cmc jackplate as high as possible on the transom and then mounted the outboard as high as I could on that. Ive done some research and found that putting a straight edge on the bottom of the boat should contact between the lip and the grate. mine barely contacts under the lip. Would having the motor set back 4 inches with the jackplate need more height? Thanks, I appreciate yalls expertise.
