Please Help Me Determine Year Make
Iverson_4x4
Oxford, AL
Could someone help me determine the year of my motor? It's a Mercury 50HP, 4 cylinder, and what I believe to be the serial number is A133058. It is stamped on a metal plate on the right side of the engine mount if you are facing the prop. The problem I am having is I cannot locate this serial number on any of the charts that I have looked at...
Any help would be greatly appreciated!!!
Maybe a pic would also help. I am assuming that it is a mid to late 80's, but since I am looking into selling it I would like to be able to tell whomever it may be the correct year.
If possible a model number would be of more help instead of a serial number. If you could find one it might help you out more.
No luck on the model number. The only other tag I could see was this one, but it doesn't have anything of use I don't believe.
Here is the tag that has the serial number. Below it it just says the manufacturer information.
