Ail
So I decided to install a 1 inch aluminum drainpipe through my transom and transom skin. I bored a 1" hole, and the pipe fits like a glove, it should seal perfectly with a slobbering of 5200. My issue is, is that the pipe actually sticks out approximately 3/16ths of an inch too far from the back, and flaring the pipe flush would be a no go without shortening it. (Unless I am missing something about the process altogether.)
So my question is, should I use a pipe cutter and take some of it off, and flare it, or can I leave it hang out the extra length and just seal it up with 5200, and then a coat of epoxy resin around the back end for extra protection against the transom? It wouldn't interfere with my trolling motor, and I could always cut it off and flare it later on if I wanted.
Sorry if I am being unclear or the situation, thanks in advance.
