Recommended tach?
If I counted the number of new or replacement tachs I ever installed, I bet it would be over 40 ... guessing 37 of them being Teleflex, 2 Faria and with only 1 original OB maker OEM installed (OMC). I bet you Teleflex or Faria makes the gauges for the OEM companies anyway ...
I have found Teleflex to have the widest color/style assortment and availability.
Simplest and probably the least expensive option is a Tiny Tach. It'll do both for you. I've even extended the wire on mine to get the tach on my dash with no issue. Good luck!
If you go Tinytach, make sure to buy the water proof model.
