Bob Landry
Does anyone make a mount that will allow the tranducer to be removed from the transon, but will have it at the correct setting when it is reattached?
First, I'm not interested in a suction cup type mount. I have both types of Humminbird mounts, one is a fixed mount and the other is the "flip up" mount that flips up when you hit something. My particular need is driven by the fact that my boat is stored in dry stack and I need to be able to remove the transducer or flip it up above the bottom of the hull and restore it to the pre-adjusted position to prevent the fork-lift guys from destroying it when they pick the boat up with their lift. I'm mounting it on a G3 1860 CC.
