My trailer is in great need of some TLC and I want to get the boat off of it and get it ship shape and Bristol fashion, but I need the boat to be off of it for a while. What do you all normally do for this? I assume calling around to places who will somehow store an un-trailered boat but I've looked around and haven't seen anyone offering that. I live in Colorado so it's not like when I was in the south and there were lakes everywhere and boat places in abundance, there are only a few boat shops around here and their yards are fairly small and I only ever see trailered boats on them.
I've thought of getting boat jacks and putting my boat up on them while I fix the trailer but that then ties up my garage for however long that will take (and prevents access to that part of the garage which I always need access to regularly) and I would be a basket of nerves anytime I was near it for fear that it would tip off. I know I need to do this eventually to do some work on my boat but hopefully that's just a weekend at a time.
Currently my only avenues seems to be to buy a new trailer, which is very hard to find used and very expensive new in Colorado, or rent a slip for the duration which is insanely expensive in Colorado with so few lakes with marinas.
It's no John boat, I've got a 350lb boat and 200lb motor to contend with, so not an easy feat to man-handle it.
I'm just a coon-*** from Louisiana, but I've had to drag 100's of lbs off the bed of my truck by chain & by rope, many plenty times. Some things are precious & fragile , others , not so much. Some can drop on the ground , others I put home made stands , saw horses or barrels to keep them high & off the ground.
My point is :
Your trailer has skids the boat rides on, right ? It's use to sliding up & off those skids cleanly. Just set the trailer in front of something you can pull against. (pole, car, tree, 4-wheeler, etc...) tether a rope from the boat to the 'anchor' (tree, pole, 4-wheeler, etc...) and slowly pull away. You can set it on some 8" post, laying on their sides, w/grooves cut in them or on taller stands made the height of the trailer rails, or on the ground for that matter.
You may need a hand or 4 but if you have room in the yard you can store your own boat. The weather shouldn't hurt it, b'c every boat I've ever seen is actually been made for getting wet ?? A tarp would cost less than a storage or other option you mentioned.
I don't mean to offend, but when you don't have money, or, when you are frugal or cheap like me, simple solutions , maybe primitive , are the way I geaux !! I mean, how long could it take to fix the trailer up w/ tender loving care ?? I removed my axle last week , sanded the rust off the whole trailer, welded a new frame pcs on the end and a couple gromets and such, changed out my springs, hubs, barrings, lights & harness and now is ready for paint, ... , all in under 2 weeks. My bosses always told me , 'DON'T OVER THINK IT' !!
That seemed like good advice for 50 yrs now and relieves stress as well.
Good luck , I'm rooting for you,
Sincerely ....................
P.S. remember not to drop the boat on your foot or your buddies foot. take it slow & geaux easy !!
