Previous owner had an old style pull switches and a separate fuse bank. Safe to assume I can replace both with a newer switch bank with the built in fuses? This would for sure allow me to cut down on the amount of wires.
Also, he had this guest switch installed. Any reason I need to keep it? There is only 1 battery for everything except for another 12v battery just for the trolling motor. There is no built in charger system.
A new trolling motor is on order so I have not read the install instructions. Can it be wired directly to the batter or is a fuse or switch best practice to have in place?
There is a 12v cigarette charger plug in the font and back of the boat. Can those be linked and ran to one of the switches? A phone charger is what these are used for.
The motor is a 20hp tiller with electric start. Should that be simply attached to the battery or should it have some sort of fuse or switch between it and the battery?
Sorry for the amount of questions and thanks in advance for the help!!!
