When I did some research on bunks, it seemed the vast majority of people prefer to stay away from roller bunks. I happen to have two 5' roller bunks that are brand-new, but debating whether or not I want to use them. I could definitely see where I would not have to back the boat as far into the water. It seems like as long as you don't do something foolish like release your winch cable before you're at the water's edge all should be fine. A gentle nudge, and the boat is launched.
On the flip side I can see where when loading the boat the friction of the non roller bunks would help to keep the boat from sliding back into the water. On some smaller boats I would imagine you don't even need to power the boat back onto the trailer with roller bunks. With a couple of side supports and a winch cable, just push the boat out into the water and then pull it back onto the trailer via the winch cable, and crank er up. I actually watched a guy do this with a 18 footer one handed. He had one rope on the stern as well to keep the boat parallel with the trailer. He sure made it look easy.
This would kind of be handy with my 14 footer, but don't think I would try it with anything bigger. Anyway, pros and cons? I'm sure it's been discussed before, but could not find anything in the archives.
Thanks,
Troy
Thanks,
Troy
